sdboys555
Posted on - 01/16/2012
I have windows 7 and with IncrediMail get the below errors
The Incredimail installation stopped due to a technical problem.
To ensure that you install IncrediMail without any further problems, we recommend that you dick the link or button below to continue installation. You will install IncrediMail using an alternative method that attempts to avoid common technical installation problems.
To fix the installation problem, click here.
Incredimail Installer Information
Error 2738. Could not run VBScript run time for custom action
Thanks
To resolve that problem you will need to register the VBScript engine using the following steps:
First, you will need to run Command Prompt as administrator as follows:
Go to the Start Menu -> All Programs -> Accessories
You will then right click on Command Prompt and from there you will choose Run as administrator
Once you have done that, you will need to run the following command:
In case you have a 32-bit version of Windows:
You will need to type cd %windir%system32 into the Command Prompt and then hit Enter
But in case you have a 64-bit version of Windows:
You will just type cd %windir%syswow64 into the Command Prompt and then hit Enter
Thereafter you will need to type regsvr32 vbscript.dll into the Command Prompt and then hit Enter on your keyboard.
Chalk Talk
