Dibri Avery
60 points
Posted on - 09/21/2012
Can anyone please help me how can I resolve the error (2.75)-3.175 and run xentry 09/2010?
The system date is fixed on 10.10.2010.
I have installed xentry console and successfully activated the code, but the program doesn’t run.
The screenshot of the error is as follows:
System error(s)
Internal error: (2.75)-3.175 Please
contact the Star Diagnosis Call Center.
OK
If anyone has any idea how to fix the issue, please do let me know. Waiting for your suggestions.
Dibri
Error (2.75)-3.175 to run xentry 09/2010
Hello Dibri,
To resolve that issue, you will need to follow the steps below:
First you will need to reinstall AS YOU ARE Xentry Diagnostics, and then you will apply the Xentry Fix.
After that you will need to apply the Xentry BlackList Fix, and then apply the Xentry Pics Fix.
Nicke
nomiuch
10 points
There are five easy steps to resolve this issue
Close the application Xentry
Change the date to May 1 (for this case only)
Delete file name times.properties
Located c:USERDATAconfigxentry
times.properties.ORIG from uninstalled application folder
most probably from
Programme / xentry / bin
Past in c:USERDATAconfigxentry
5. Rename times.properties.ORIG
To
times.properties
You are Done
Thanks to both of you. Your advice is very nice and helpful. Nicke Baker, I am pleased with your solution and your solution is very easy. After strictly following your advice, I was able to fix my problem. Thanks again for making me tension-free by providing a good remedy. In fact, I am not getting any error messages. Really superb remedy!
