Error – 29501 Citrix Presentation Server uninstallation
20 points
Posted on - 02/27/2013
Yesterday I attempted to uninstall Citrix Presentation Server but I was failing because of the following error message which you can set the below attached image. How can fix this error? If somebody has an idea please share.
Thanks in advance
Error 29501. Setup has determined that Application Isolation
Environment exist on the server. Remove all of these before continuing with uninstallation.
