My Adobe After Effects CS5.5 software is displaying Error 3 or Error 6 while using it. It works perfectly fine for 2-3 uses after installing it. Later it throws the error message and I have to repeat the whole process of installation. How can I get rid of this?
Error 3 on running Adobe After Effects CS5.5
The errors that you are receiving is usually caused by some of the important files that are required by the adobe after effects application missing on the computer products. You can be able to check if the file pcd.db that is found in the folder <Drive>:/Program Files (x86)/Common Files/Adobe/Adobe PCD/ is still there or in case it has been deleted due to some reason.
In case the above mentioned file is available in the mentioned location, then there should not be an occurrence of such a problem. In case it is not there, you will need to try reinstalling the after effects application. If the problem still persists you will need to contact adobe tech support for further assistance.
-Keegan Robb
