“Error 3044” when running a macro on MS Access
Hi everyone,
A front end DB is performing fine on all computer except one. When DB is running, it wants the username and password. After entering those, they choose the enter command button that opens the Home Form.
The home form is associated with an OnOpen event along with an embedded macro whose task is to open a hidden form that is kept open during the whole session. The message box shows that the problem is for this form. We get an error message box after pressing the enter button.
Error is below:
Macro Single Step (MsgBox Name)
Home: Form: OnOpen: Embedded Macro (Macro Name)
Open Form (Action Name)
3044 (Error number)
FrmKeepOpen, Form,,,,Hidden (Arguments)
The 3 button options on the message box are "Step" which is disabled, "Stop All Macros" which appears enabled and highlighted, and "Continue" which appears disabled. This problem is only found on this computer.
What step should I follow?
Thanks in advance.
