Error 372 when I started the SBuilder application.
I got an error 372 when I started the SBuilder application and clicked on New Project.
I have seen some post about the same problem but so far there has been no reply.
Please see the image below.
I am Hoping someone can help me resolve this time.
Thanks in advance.
Sbuilder
Run-time error '372':
Failed to load control 'SSTab' from TABCTL32.OCX. Your version of TABCTL32.OCX may be outdated.
Make sure you are using the version of the control that was provided with your application.
Answered By 590495 points N/A #144333
If this is the first time it happened when using SBuilder, try restarting your computer then try it again. If the program failed again on your next attempt, check if you are using the right version of the file tabctl32.ocx for your application. If the said file is included in another supporting program of SBuilder, maybe you need to upgrade it to a much higher version.
You may also try reinstalling the whole SBuilder package just to restore the program to its default configuration and fix any corrupted files that may have affected the program from functioning correctly. Uninstall SBuilder then check your computer for any possible errors. Use a disk utility application to check the system. Install SBuilder again after this and then check if this fixes the problem.
If you are using an older version of SBuilder, try downloading and installing SBuilder 205 for FS9. For more information about this download, you may visit SBuilder for FS2004 download.
