Error 403 on downloading updates in Xperia Neo
Hello.
I have a Sony Xperia Neo mobile phone and I keep getting an Error 403 on downloading updates.
The update will start and it will stop with this error.
Can somebody please help me?
Hello.
Hi Andre,
I have read your concern about updating your Sony Xperia Neo. Most of the time this kind of error appears when while updating your phone your connection drops and even if it was just for a moment the download would fail.
I suggest that you try to download where you have a good signal and internet connection.
Hi Andre Ford,
I have reviewed your concern and try to resolve your problem. Please follow these steps to resolve this problem:
Go to Settings > Wireless and Network settings > Mobile Networks > Access Point Names (Yours Current service provider).
If there is a set of number in the PROXY, remove it and click Ok. You will notice that it will be written < not set > after you do it.
I wish this solution may be helpful. Thanks!
Best,
Fenster Maxine
The Sony Ericsson Xperia Neo is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on February 2011 and released on March 2011. It measures 116 x 57 x 13 millimeters and weighs 126 grams. It supports mini-SIM card. It has LED-backlit LCD capacitive touchscreen display with 16M colors at 480 x 854 pixels screen resolution.
It supports multi-touch protected by scratch-resistant glass. It runs on Android 2.3.4 Gingerbread upgradable to Android 4.0 Ice Cream Sandwich powered by Qualcomm MSM8255 Snapdragon S2 chipset, 1.0 GHz Scorpion processor, and Adreno 205 GPU. It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with 320 MB internal storage.
The primary camera supports 8 megapixels with LED flash and autofocus featuring geo-tagging, touch focus, video calling, and face and smile detection and supports video in 720p at 30 fps. It has a secondary camera, 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 2.1 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0.
It has built-in accelerometer, compass, and proximity sensors. The preinstalled web browser supports HTML with Adobe Flash support. Java is supported via Java MIDP emulator. It runs on removable Li-Ion 1500 mAh battery with standby time up to 430 hours on 2G and 400 hours on 3G. Talk time is up to 6 hours 55 minutes on 2G and 7 hours on 3G.
It is available in red, silver, and blue gradient colors.
