JohnStevvy
30 points
Posted on - 07/23/2011
Dear Reader,
I am having problems with my internet connections. Initially, it was all fine. Now, for about one month, I have been getting this error
'PAGE NOT FOUND'
It has persisted and I cannot access this page. It is very important that I access it for my own good. I have a perfect internet connection. What should I change to be able to access this page? Or was I blocked?
Thank you.
ERROR 404 EVEN WHEN THE INTERNET IS ON
For this check your URL even if a single word of your URL is typed incorrectly you get this error. Or clear all the cached data in the internet explorer.
Open an internet explorer click safety and then click delete browsing history in delete browsing history area click delete .With this your browser is refreshed and you will not get that error again…hope this will help you…..
In this Solution you should first check out your page is there with help of FTP client if it is there then check following possibility for that
1. First check where you put you page means it is link or direct your are entering in your URL. if you given as a link of that page then check any spelling mistake is not there or any space or symbol or blank space for that link.
2. If you entering direct that page name in your URL address then also you check all the possibility like your using correct spelling without any mistake.
3. Other possibility is if you changed that page extension you can check that also.
4. Or You can clear your cache data if your using Internet Explorer, Google Chrome, Firefox etc then press CTRL + Shift + Delete together so you can able to clear you cache data from your browser then refresh it.
Thanks
Lakha
