Error 5 shown while running command with IVI drivers
Hi Pro,
When I download the IVI drivers installation folder it was in the WinZip form. Then I extracted in C drive and I installed it. The problem triggered while setup, am I doing anything wrong. Any file is missing while extract? Do I need any permission from tech support department? Frustrated, please help me out. Thanks.
Error 5 running command .setup.exe
Answered By 15 points N/A #178473
Hi Stephen,
The error is because the setup file does not have the permissions to execute it.
To solve this error follow the steps stated below:
1) Navigate to the directory where the setup.exe file was extracted
2) IVI drivers uses the Winzip selfextracter to extract files
3) The files are located in the path <National Instruments Downloads>IVI
4) Locate the setup.exe file associated with the IVI driver
5) Run the setup.exe as an administrator and the error will not be displayed on the screen
