I have a MAC with Lion OS X, core 2 3.3GHz, 8GB RAM and when I try to run Adobe Photoshop CS5 this error message box appears on my desktop. When I try to open Storyboard Configuration this error message appears again. What is the error with this Photoshop on my MAC ? Please help me to install it properly.
Kind Regards !
Error 519: Server interface error “Error from createlmageSet(3,2, /private/var/ folders/
67/45vIhdgl10h78hkmn735sxpxr0000gp/ T/Temporaryltems/ storyboard-2012_0404B_Canon5D#2Rain bow5.jpg.jpg.100,67,0,undefined,0,0,0,undefined,0,0,0,undefined,0,0):
ActionScript error: Error: Error #3003
Line: 102
OK
Error 519 Server interface error occurred
Officially, Adobe Photoshop Creative Suite 5 supports Mac OS X 10.5.7 Leopard until 10.6 Snow Leopard. These are the editions where Adobe Photoshop Creative Suite 5 has full support for. Though I’m not sure if the program still supports or will work 100 percent on Mac OS X 10.7 Lion, there are users of Adobe Photoshop Creative Suite 5 that proves that this version works.
But the only problem is that you might encounter some problems since the operating system is not officially supported. One user has installed Adobe Photoshop Creative Suite 5 Master Collection and according to her, this version worked on Mac OS X 10.7.1. The only thing that struck her was when Fireworks suddenly failed to work the next time she used it after the initial launch.
She suspects that an update she made on her operating system probably caused the program to no longer be compatible. If you have Mac OS X 10.7 and not higher, you probably need to stick with it if you wish to prolong the use on Adobe Photoshop Creative Suite 5. Try reinstalling it. It could only be a corrupted file causing the error.
If reinstalling won’t help, the next best thing to do is to purchase and install Adobe Photoshop Creative Suite 6.
