Error 651 internet explorer connection
Downloaded Google Earth does not run directly. It is always opens Internet explorer dial dialog which does not give connection due to the error 651. What do I do?
Hi There,
I have some method to overcome your problem.
It can be a problem of your driver file. You can find this specific driver files in C:/ Windows / system32/ drivers folder. (assuming that you have installed Windows in C: partition in your computer).
Find and locate the diver file name "raspppoe.sys" and simply rename the file as another name just like "raspppoe_myfile.sys" don't change the file extension or you can copy and replace a file from Windows Vista computer (if you are running windows7) If you don't have the access to system files, you can download it from the link.
Just download the error 651 repair tool link and run it.
Then if it finds any problems in your system, they will be fixed.Â
Thank you.
Hi!
