Error 651 Windows 7 Internet Connection
Hey, How to fix error 651 windows 7 internet connection in windows also please show the step wise procedure for the easy understating of it. Thank you in advance.
To overcome the error 651 windows 7 internet connection you need to follow some steps which are as follows:
• First reconnect your router as it’s the basic troubleshooting step to do.
• Reset the TCP/IP of your PC
• Recreate the dial up Connection by going to Network and Sharing Center > Change Adapter Setting > Create Copy.
• Disable auto tuning feature
• Disable IPv6 from your Internet connection buy going to Network and Internet > Network and Sharing> Active Network Connection.
