xyjimenez
Posted on - 02/25/2012
Hi all,
This is the error message that I received when scanning an IP range:
"An unexpected error has occurred. The operating system returned error message 67 the network name cannot be found."
I have tested all the useful settings needed to solve it but nothing’s changed. What are the required steps?
Thanks in advance.
Error 67 when scanning an IP range
Cause:
The occurrence of the issue can be traced to one of the following two reasons:
1. Configuration issues with the network card on domain controller.
2. Issues updating the network drivers on a domain controller.
Resolution:
Step 1:
The network adapter driver should be updated on the domain controller. The driver used should be in accordance with the operating system.
Proceed with Step 2 if the issue is not resolved by this step.
Step 2:
The issue can be rectified by disabling the Internet Protocol Network Address Translator driver.
1. Click on Start > Run and type devmgmt.msc to open the Device Manager.
2. Click on Show hidden devices after clicking on the View Menu.
3. After clicking on Show hidden device, the Non-Plug and Play Drivers appears. Right-click on IP Network Address Translator, under Non Plug and Play Drivers to disable the same.
4. Restart the computer when prompted to do so.
