I am trying to connect to VPN and it's giving me Error 69. I did not find a WAN PPTP miniport when I checked the list of network adapters. It's the only protocol supported by our VPN. Do I need to restore or reinstall the port? Any suggestion on how to fix it? Thanks.
Error 69 when connecting to VPN, missing WAN miniport (PPTP)
Try to reinstall the port first.
If the error appears still and If you are usuing ASDM follow steps :
Go to the configuration > Connection profile > Double click on the port you need to change > advanced > change the IKE negotiation mode.
The modified crypto should look like this :
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set peer <peer IP>
crypto map Outside_map 1 set transform-set ESP-AES-SHA
crypto map Outside_map 1 set security-association lifetime seconds 28800
crypto map Outside_map 1 set security-association lifetime kilobytes 4608000
