Error 8002F147 while trying to update firmware3.50
I have been aiming to solve my ps3. I have tried to update firmware 3.50, but I am getting 'error 8002F147', when the install process in 20%.
I have also formatted the disk many times, and tried installing a previous version of this software. Recently, I also tried to update 3.56
If anybody knows how to repair this problem, please help me.
It has been more than 1 months without my ps3! Please help.
Best Answer by Georgien Fuller
Answered By 0 points N/A #153504
To solve your problem just follow the following steps.
Step 1:
Take out your hard drive and then connect it to your pc
Step 2:
Open disk management in windows 7 and then format it NFTFS format .
Step 3:
Get the rom and copy it to the USB drive then Update and lastly put the name PS3UPDAT>PUP
Step 4:
Shut down you computer and take out the USB drive.
Step 5:
Put USB in ps3 and boot ps3 and then click start on the screen.
Step 6:
Configure your ps3 setup. Now it is done.
Answered By 0 points N/A #153505
Try to reinstall the update using the Safe Mode, and you can go to the safe mode by following these steps:
Step 1:
Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep.
At that point release the Power button.
If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
Regards.
