Error 803d0010 on Deploying Bare Metal with VMM 2012
I am deploying Bare Metal with Virtual Machine Manager (VMM) 2012 but it always failed and gives me an error 803d0010. I opened the command prompt window but the trace log has some blank entries. How can I correct this?
System Center Virtual Machine Manager 2012
Error: 803d0010, The remote endpoint was not reachable. Press SHIFT+F10 to open a command windows, A trace log is available at X:VMMvmmAgentPE.exe.log. this file will be deleted when this machine reboots.
Best Answer by brionas brain
Answered By 25 points N/A #125426
Good day Tori Lawson
I have found a solution for your problem when you receive the error try to press shift+F10 in the bare metal with virtual machine manager (VMM) , then type ipconfig /all and try to check the Domain Name System (DNS) Internet Protocol (IP) address if it has been taken on bare metal with virtual machine manager (VMM) or not. If not, name the server entry in DHCP.
This solution is according to my research and it is proven to work. Enjoy in deploying your bare metal with virtual machine manager. Enjoy your stay here.
Answered By 0 points N/A #125428
After updating spam functions, wrong arguments set in baremetal/driver.py code. instance'['id'] should be replaced with this instance['uuid'] in db.instance_update_and_get_original(). And it must disable_auto_fsck flag which is not used anymore and shows unnecessary status fields. To fix the problem, when the error appears, press Shift+F10 in BareMetal.
If you do this with the virtual machine manager, it will try to check the Domain Name System Internet Protocol address. It will take on BareMetal with the VMM (Virtual Machine Manager). If it doesn’t happen, put the name in the server entry in DHCP. You should see the progress of BareMetal with VMM.
