An error about vb6 wave get volume.
Hello experts,
An error about VB 6 wave get volume. I just don’t know what happen to my VB 6 coding which has an error of getting wave volume when opening the audio. I hope you can give some suggestion about the coding process in VB 6 programming language.
Thank you.
Answered By 60 points N/A #182326
Hi Vanessa Onnoya,
I have searched the internet and Google for possible solution  with your problem. I think you need to have a lot more information about VB 6 so that you would not encounter more problems in the future. I have attached a link for your reference. I hope it would help you with VB 6 problems.
Visual Basic 6 Tutorials
Thanks and more powers.
