Error on accessing iCloud: Exception TypeError
Hi all! I am trying to access iCloud but each and every time, I always got this error “EXCEPTION TypeError: ‘null’ is not an object”. How can I resolve it?
Hi Cecil,
I have read your concern about error on accessing your iCloud. Probably, Apple confirms about the iCloud error and some users will unable to access some older email messages. They have issued System Status update on iCloud Support web page and some users might be affected. It was confirmed last July 31st and Apple has promised that it will be resolve as soon as possible.
Hi Cecil,
This issue as per Apple should be resolved by now however, if you are still experiencing such issue, you can try this solution: Delete the ServerVersion.plist found under Volumes > Mac HD > System > Library > CoreServices. This is caused by a JAVA script error and by removing the file refreshes it and installs and updated version. You can also use a JavaScript debugger to know what is causing the problem.
Notifications
