Error on accessing VPN with Remote PC
I have computer networks with all the severs working well. And then, I tried to let the remote pc to access VPN and that is where I started having trouble with LAN. Connected computers can’t reach the main server even using a static IP address. I tried to remove routing and remote access but still it’s not working. Can you please help on how to fix this?
Best Answer by Akhla
Answered By 0 points N/A #105637
When you have been wanted to continue with your computer server networking smoothly you must have been buy a new 10/100M PCI Network Adapter Model No:TF-3239DL that is a Lan card to set your computer for networking within VPN.You should have to go to control panel to set up your VPN server by the local ISP.You may have your subscription with their services.They will give you an IP name and a password to active your VPN server into your computer sooner.You must set the lan card to your computer CPU and can move.
Answered By 15 points N/A #105638
Hello Jonathan Watson,
I think, you’re your VPN is blocking you from accessing your computer .
The reason is, once, your VPN tunnel is established, one end of computer or network only be able to access the other end.
As long as your VPN is established, you should disconnect your LAN. After the VPN tunnel is established, you can connect the LAN to access the shared drivers.
Hope this may solve your problem.
Paul Jolie.
