Error with Acrobat Reader software
Why am I getting an error (Error 109) while using Acrobat Reader.
I have acrobat reader installed my laptop yet I can not be able to use it
If you received that error 109 after double-clicking a PDF file, check first if Adobe Acrobat Reader is really working. On your desktop, double-click the Adobe Acrobat Reader icon to open then see if the application starts successfully without popping out any error. If after this you get an error then the problem is with your application not the PDF file.
In case you are using an old version, download the latest version, Adobe Reader 11.0.10. It supports Windows 2000 32-bit only, Windows XP, Windows Vista, Windows 7, and Windows 8 both 32-bit and 64-bit. Once downloaded, uninstall your current Adobe Reader. Click Start, Control Panel, and then Add or Remove Programs. Select Adobe Reader from the list then click Remove or Uninstall.
When finished, click Start, All Programs, Accessories, System Tools, and then select Disk Cleanup. Select drive C then click OK. Check Setup Log Files and “Temporary files”, click OK then select Delete Files. Restart your computer. Navigate to the download folder then run the installer you downloaded to install Adobe Acrobat Reader 11.0.10. It should fix the problem.
