Error adding Admob ANE into the Flash Builder project
I am trying to add Admob ANE into the Flash Builder project and this error appears and after I press the OK button the program is closing. Any solution for my error ? What I did wrong ?
Thank you experts !
Launch failed
Process terminated establishing connection to debugger.
The content cannot loaded because there was a problem loading an extension: Error:
Requested extension so So.cuo.ane.Admob could not be found.
Launch command details: “C:Program FilesAdobeAdobe Flash Builder 4.
7 (64 Bit)eclipsepluginscom.adobe.flash.compiler)4.7.0.349722AIRSDKbinadl.exe” –runtime
mobileDevice-screensize 480×762:480×800 –XscreenDPI 252 –XversionPlatform AND
“C:UsersSAMSUNGAdobe Flash Builder 4.7testadmobbin-debugtestadmob-app.xml”
“C:UsersSAMSUNGAdobe Flash Builder 4.7testadmobbin-debug”
