hi TechyV,
When I try to use the texture panels in my adobe fireworks CS6 I get the following error message saying something about the entities that can be filled.
Can anyone tell me what is happening here? And how can I implement color fills there?
Adobe fireworks CS6
You cannot apply a fill texture to an object that does not have a fill.
Error – Adobe fireworks CS6
Hello there,
Simple solution for your simple problem; add a fill or stroke, if you’re trying to apply fill texture to an object without fill or stroke, this error message will probably pop.
and take not to make your opacity to < 0 as you will not notice that you already added the given texture .
A fill corresponds to a color, pattern or a gradient inside an object. You can apply this fill option on both open and closed objects and also to faces of live paint groups.
Whereas a stroke mainly refers to the visible outline, a path or an edge of a live paint group. You can also create dashed strokes from path options and paint styled strokes using the brushes. All depends on the requirements.
You can get all the details of these features on this Adobe help link and in future get rid of these frustrating problems.
