I want to uninstall Adobe Photoshop from my computer as because I have installed in another computer.
But I am getting an error here. Please take a look:
Error:
Adobe Photoshop CS and Imageready CS
>setupDLLsetupDLL.cpp (442)
PAPP :Adobe Photoshop CS and Imageready CS
PVENDOR : adobe https://www.adobe.com/)
PGUID : EFB21DE7-8C19-4A88-A766E16493BC
$7.1.100.1248
@windows XP service Pack 3 (2600) IE 8.0.6001.18720
Error in Adobe Photoshop when uninstalling
You can remove it manually to your computer if it you cannot remove it using add remove programs from control panel. Go to drive where you install adobe Photoshop, Normally you can locate it to C:Program Files. Delete the Adobe Photoshop folder. It is not yet finished by deleting it to the folder where you installed it. There is called a registry. You need to delete also application registry keys and uninstall registry keys.
Delete also application registry keys
go to start then type regedit to search programs and files textbox then click enter. Then locate to HKEY_CURRENT_USERSoftwareAdobe then delete the adobe folder
Uninstall registry keys
The same step from above, go to registry, but this time you need to locate to HKEY_LOCAL_MACHINESoftwareAdobe then delete the adobe folder
