Error on ADSP-21479, SPI Flash
I am getting this error on ADSP-21479, SPI Flash. "Port doesn't exist or isn't opened with PC at 0x124450"
Hello, everyone! I need your help with the error I receive when using the Flash Programmer. I use the Flash Programmer to save the test code to the SPI memory of Flash that is on located on the developing board. I am doing this so that the code would automatically run every time the board is switched on.
Previously, the other codes that I have are working with the board by passing through the USB ICE. Now, these codes are no longer working as they used to.
I have tried to isolate the problem by running the code that is used to read and write the Status Register in Flash, in other places. I get this error when I did that.
Error: ***port doesn't exist or isn't opened***with PC at:0x124450 |
I have no idea what the error is for and I also have no idea how to fix the issues I am experiencing. I need help in fixing this. If you could give any recommendations, I would really appreciate it. Thank you so much!
