Error after 70% installing Oracle Database 11g Release 2 installer
While installing Oracle Database 11g Release 2 installer, it was going on smoothly, but on completion of 70% installation, it threw an error message. However it continued after throwing the error message. The error message says “Error in invoking target ‘agent nmhs’ of makefile”.
Have you any idea of the message. Should I try a fresh one?
Please help.
Answered By 30 points N/A #148326
Hello.
There is a compatibility issue with your operating system and Oracle Database 11g Release 2 installer.
However you can continue using the software. But it may cause problems in the further use.
My suggestion is to try to download the version which is compatible with your operating system.
Click on the below link to check with download the version which is compatible with your operating system.
http://www.oracle.com/technetwork/database/enterprise-edition/downloads/index.html
Thank you.
