Error after doing a system restore
How does error "ANS1949E Microsoft volume shadow copy snapshot initialization failed.ANS1949E Microsoft volume shadow copy snapshot initialization failed." Result from after doing a system restore on my laptop.
HI there ,Â
It seems you are having trouble after restore .Â
This error message pops when the restore and backup wizard failed to successfully restore your device to previous pointÂ
You can do one thing that is just try again .Â
If it fails again then The problems are 2 : –
1. Your Restore point and the files are corrupt.
2. Huge loads of Malware and or Viruses are Playing with your system . You must be very careful while using External devices to install Softwares and other stuffs and also while using Network.
