I tried loading a Blogspot.com website when I got the following error in Internet Explorer:
"Windows Internet Explorer
This windows is busy.
Closing this window might cause some problems.
Do you want to close it anyway?"
I have refreshed the page, but IE looked like it suddenly stopped responding. Could anybody please help me troubleshoot it?
Error After Trying to Open Blogspot.com Website
Please click on " Diagnose connection problems" and wait for the system to tell you about the solution of the problem. It might be network connection problem from the internet server feeding the system. Also close other windows or browsers you using meanwhile and make sure the load is not too much for the server.
Thank you
Hi Willie,
Here are the things that you can do about this problem:
1. Try viewing another website (example https://www.google.com/?gws_rd=ssl or www.yahoo.com) and if they open without having this error, the fault is with blogspot. It might be because they are currently doing some maintenance on their site.
2. Check if you have network issues. Connection problem might cause your Internet Explorer to be unresponsive.
3. Delete your IE browser history.
4. Disable any add-ons and/or third party toolbars.
5. Run your antivirus and anti-malware program. This causes problems especially to IE.
6. Use a different kind of browser (such as Mozilla Firefox or Google Chrome)
Hope you get this problem fixed sooner.
