Error al conectar con el motor
I had to update my Window 7 and now Hamachi gives me this error. I tried to reinstall the latest version of the program and is not working. Can anyone help me please to fix this ? What is causing and why I have this error ?
Thank you !
LogMeIn Hamachi
Error al conectar con el motor.
Aceptar
Answered By 590495 points N/A #176552
It’s kind of hard to comprehend because your image is in Spanish I think. Good thing there is the Google Translate than I can use to translate the message. In English, the error says “failed to connect to the engine” and then “accept”. If this is what LogMeIn Hamachi says then the program doesn’t really run.
If you just updated your operating system using Windows Update, try restarting your computer and try LogMeIn Hamachi again. If it doesn’t work, uninstall your existing LogMeIn Hamachi then click Start, All Programs, Accessories, System Tools, and then Disk Cleanup. Select drive C and click OK. Check “Temporary files”, click OK and then click Delete Files.
After this restart your computer. Download the latest version from LogMeIn Hamachi Download but don’t install it yet. Check your operating system if you are already using Service Pack 1 because it is the latest Service Pack for Windows 7. If not and you are just installing minor updates from Windows Update, download and install Windows 7 Service Pack 1 [KB976932].
After the Service Pack update, restart your computer. Next, run the installer for LogMeIn Hamachi you just downloaded and install it.
