Error appears on PC running 3GB of Ram and quod 4 processor
This is our problem. Different variations of the same error message appear saying:
"After Effects error: unable to allocate space for a 4752 * 15766 image buffer. You may be experiencing fragmentation. In the memory & cache Preferences dialog box, try decreasing the maximum RAM Cache Size value and selecting the enable Disk Cache option, increasing Maximum Memory Usages, or both. (7::66)"
This appears on our PC running 3GB of Ram and a Quad 4 processor. We are also having problems rendering on our Macs as well. The error can appear on a very simple project which has no blur or major effects put onto it as well as complicated ones. We've been through the memory cache settings and other suggestions found on the web but to no solution. Any other ideas we can try? All computers seemed to be running fine until recently.
Many thanks in advance.
