An error appears while I am opening a drawing file
HI! I am wondering what is an open drawing-errors found as this appears when I opened one of my drawing files.Â
Open drawing error found
One error was found in the drawing file during open. Would you like to cancel this open?
It is recommended you cancel the open and then run the RECOVER command on the drawing file.
There was an error discovered in the drawing file while opening and it added if I will just abandon it.
It also suggests if either I will cancel the open and move on with recover command in the drawing file.
Should I just cancel this? I hope someone will drop by to give some solution to resolve this.
