Error Application module cannot be found
Hey,
I am getting this error message on and off in the computer. I get this error mostly when I start the computer, after a while when I run quick scan, it works fine. This error is not creating any problem, but it is very annoying. How to stop this error from popping? I tried to uninstall and reinstall the antivirus but nothing worked. Please help. Thanks.
The application module
C:Program FilesAviraAntiVirPersonalEditing Premiumrcimage.dll
cannot be found or has been modified or destroyed.
The AVWSC.EXE cannot be started.
Please check your installation!
Best Answer by Tim Lahaye
Answered By 1065 points N/A #189143
First of all, the most common reason why this error occurred is due to software compatibility. So ensure that you are not using more than one antivirus or scanner since it will cause conflicts on your computer. You need to uninstall the others before you can use the other one without issues. You can also try to update your Avira AntiVir.
Answered By 10 points N/A #189141
The avwsc.exe error is a common error from windows or other window compatible software. The avwsc.exe error may cause by windows system files damage. You can try the following link to use free downloadable software to cure the windows executable related error.
avwsc.exe Error Fix
Also, another option could be to try to restore back the system into a earlier saved restore point this could be done from windows system restore utility. You may also try using some standard registry cleaner software as well to fix the issue Reg Cure Prosetup.
After each process ensure that you reboot your system.
