Error on the attached picture of Street View images
Hello friends,
I was only looking at Street View images from Google Maps when I received the error on the attached picture.
Internet Explorer Script Error
An error has occurred in the script on this page.
Line:          1
Char:         25
Error:         Systax error
Code:         0
URL:         file:///C:/Documents%20and%20settings/hristop/Local%
               20Settings/Temp/tmp215.htm
              Do you want to continue running script on this page?
                                     Yes          No
Is it a problem with the site or browser? What should I choose, “Yes” or “No”? It sounds like it can damage my browser.
Please give your opinion.
Thanks a lot.
Answered By 0 points N/A #134183
Script errors in Internet Explorer are common. Have you tried the street view of google maps on other browsers like chrome or firefox?
If you are see the error but you can also browse through the webpages then its nothing to worry. You can just dismiss the error and continue with your work.
Try opening the websites in other browsers. If the problem persists then go clear out all the temporary internet files.
Install the latest version of Internet Explorer. Always keep updating softwares for optimum performance.
Hope this information helps you.
