Error in Authorizing Mac OS X 10.6.8
I used Mac OS X 10.6.8 and I am having issues on authorizing it. I always get “0xfd from Server – Internal Server Error”. I already re-installed License Manager but the error is still shown. The rest is working such as GearBox and POD Farm. I also have TonePort DI-G. I need help and advices. Thank you.
Best Answer by Sharath Reddy
Answered By 25 points N/A #126116
Try it again maybe they are fixing the server.
Answered By 590495 points N/A #126117
If you usually get this error every time you use the application, why not try restarting your machine and then try it again to see if it works the next time around. If it doesn’t, maybe there are other problems in your system that needs to be checked. The problem here is that, you did not mention in your post the name of the application where you usually encounter this problem. I’m also not familiar with GearBox and with POD Farm and when I checked their official website I learned that they are applications for audio equipment.
The reason why you are not having any issues with GearBox and POD Farm is maybe because you are using the correct version or latest version of their drivers on your machine that’s why all works well. Since I don’t have an idea on what program you are having problems with, try doing another clean installation of the application just to restore it to its default configuration and also fix possible corrupted files that may have developed in the program. Uninstall the application then check your computer for any possible errors. Use a disk utility application to check the system. Install the program again after this and then check it if it’s working.
You should also check their website for the program’s latest update for your Mac OS X’s version. To know more about the application’s latest updates, you may visit Line 6 — Downloads section.
