Error because of missing Flash Plugin in Internet Explorer
Asked By 7060 points N/A Posted on -
Hello.
I am currently facing a problem. I am seeing an error message that says "Class not registered".
After doing some investigation, I identified that the error occurs because of a missing Flash plugin in Internet Explorer browser.  I'm really puzzled right now.
Please help me find the solution.
The KMPlayer
Answered By 15 points N/A #82293
This type of error is such a mess. This makes you unable to play any video clip over internet browser as well as Windows media player. There are certain ways to fix it.
This will solve by checking dll (dynamic link library) file and in fact install it. Press windows button+R from your keyboard. A RUN screen will come up. Now enter a directx  related dll:  regsvr32 quartz.dll and press ok. And then finish with successfully installed.
Either way is you can download Adobe flash plugin or Adobe flash player directly from internet at the link given below
Scroll down the web page, you will see the heading ‘windows’. Within this heading you see the link like:
URL: Download the Windows Flash Player 11.1 ActiveX control content debugger (for IE)
This link is for Internet Explorer.
You should click the link as according to your internet browser
