Error BlackBerry Travel Error Message
I have this error on my BlackBerry when I want to start BlackBerry Travel application and I don’t have a solution for this one. Does anyone had this before ? Can anyone help me please to solve it ?
Thank you experts !
Error: BlackBerry Travel Error Message
Answered By 0 points N/A #181591
Hi Jamal,
Sometimes it appears because when you update that application or that feature of blackberry, files are corrupted. You can restart your device and check if the error appears again. If it does try to re-install the updates on your device. Make sure that your internet connection does not have problem or will not disconnect to prevent from file corruption.
Answered By 590495 points N/A #311076
If the BlackBerry app is no longer working properly, just try deleting it and install a new version. Since it is not clear what version you are using, just try downloading BlackBerry Travel. This is BlackBerry Travel 2.6.0.99 released on July 11, 2013. It requires BlackBerry Smartphones running on BlackBerry 7.1 operating system and earlier.
This version is BBM-connected which allows you to share travel plans and flight changes directly with your entire BBM community or select BBM contacts. It also adds support for Turkish localization. If your BlackBerry Smartphone runs on a much newer platform, go to BlackBerry Travel for BlackBerry 10. This version is integrated with your BlackBerry ID.
It also features a new Price Alert service which lets you know if there’s a better price for that hotel room, a comparable hotel for a cheaper price, or if there’s a much better hotel for slightly more.
