I have just got the ORM trial program and while installing it, the following error box shows up. Do you know why?
It is important for me to fix this, as I need it.
I Google it, but couldn't find any relevant information.
Please help me.
Thanks in advance.
Error box shown while installing ORM trial program
If you are using Telerik OpenAccess ORM, check again the compatibility of your computer with the program’s technical specifications. It’s possible that your system has an incompatibility issue with the application.
Telerik OpenAccess ORM supports these development tools: Microsoft Visual Studio 2008 and 2010 [Standard, Professional, and Team System]. Supported database for Telerik OpenAccess ORM: Microsoft SQL Azure, Microsoft SQL Server [2000, 2005, 2008, 2012, 2012 Express, and LocalDB], Microsoft SQL Server Compact [3.5, 4.x], MySQL 5.x, Firebird 2.x, Advantage Database Server [9.1, 10.1], Sybase SQL Anywhere [11.x, 12.x], Oracle Server [9.2, 10.x, 11.x],
Oracle Database [10g, 11g Express Edition], VistaDB, SQLite, and PostgreSQL 8.4+. To better understand it and to see the complete list of the system requirements, you may visit OpenAccess ORM – System Requirements.
To download the installer again, you may visit Telerik OpenAccess ORM.
