There is a XMMP server for large (mostly) Russian social network vkontakte.ru.
Beejive was not able to connect to the server with Push. It's saying that username. Or. Password. Invalid.
I guess the server expects to see login sent without the @domain.com part.
I.e. my login there is [email protected], but server expects to see nadvorny only as login name. But for Beejive its not allowing to go online with a login without the @domain.com part.
How can I login to the server? (Note I am not able to connect to it with IM+, Pidgin and Adium clients so this almost certainly Beejive issue).
VKontakte
Error: Cannot connect to the server
Hello
In connection with your concerned issues on Beejive, it has been detailed that BeejiveIM supports invisibility for AIM®/iChat®/MobileMe®, MSN®, Yahoo® & ICQ®., click lisisoft website and find out JabberB – BeejiveIM for Jabber 1.2, this app lets you access jabber/xmpp on the go, take note you don’t need to access multi protocol support , get all major beehive features in the streamline apps. And learned more.
Thank you.
Thomas
Hi there Suzanne Lerson
The problem occur because of the earlier software installation so in order to avoid this follow these steps
Step 1 – Go to Start > Run > Type regedit and hit enter
Step 2 – Locate this path
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession Manager
Step 3 – Find “PendingFileRenameOperations” & Delete it
Step 4 – And locate this path also
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionWindowsUpdateAuto Update
Step 5 – Find “RebootRequired” & Delete it
Step 6 – Close the regedit and restart the computer
Best of luck
Taylor B Campos,
Thank You
