Error “Cannot Find an Exchange Installation”
I am using Exchange 2000 and 2003 Server 5.5 but I cannot get it to connect. It displays an error message of “Cannot Find an Exchange installation.”
How will I correct this situation?
Maybe you have not configured the two exchange servers properly and that is why they are not able to establish a connection. If the error is occurring when you are importing PST files, then you will need to know that the only supported solution for importing PST files will be to first of all install the management tools on the machine that you are using.
The management tools may refuse to if you are using SP3 machine not unless you happen to have a 32-bit Domain Controller from which you will be able to copy the Ldifde.exe file that is needed.
Some other thing that you will need to check is the network connection settings, you will have to check and verify that the settings are correct.
-Richard Gabriel
Notifications
