Error: “Cannot map the project with SVN provider.”
Hello there. Please see the picture below regarding the problem I got. I am stuck with this problem and I need some help. I was trying to connect to SVN repository when an error log came up saying Error: “Cannot map the project with SVN provider. ” Do I need to add all suggested plug-ins that are required to Eclipse IDE? Can you give me any suggestions on how to fix this error? Thank you.
