Error to change regular expression in WPI/IIS7 – SQL
Hello there,
Hello there,
If you are using windows 7 run the installer as administrator.
Then choose yes and continue.
If you are using Windows XP, login using Administrator user account then try to install.
If this do not solve the problem use the next technique.
At the time of installation select windows integrated authentication
Later, after installation use Microsoft SQL Server Management Studio Express to configure the username and password.
Download link:
Microsoft SQL Server Management Studio Express 2005
Microsoft SQL Server Management Studio Express 2008
If need help about how to configure Microsoft SQL server using Management Studio Express, please click here.
