bellaross
Posted on - 03/06/2012
When opening a Adobe Reader file from a client mapped network drive using client to server content redirection, I get the following error message
There was an error opening this document. Access denied.Â
I use XenApp 5 for Windows 2003 server. I uploaded a screenshot to better understand my problem.Â
Please help.
Thanks!
Error in client to server content redirection of Adobe file
If the Adobe Reader file you are trying to open is mapped from a network drive, it is possible that you don’t have enough rights to open and view the file from your workstation. You may try copying the Adobe Reader file to your local hard drive and open it there.
If you still receive an error even if you already copied the file to your local hard drive, try uninstalling and then reinstalling Adobe Reader X to fix any corrupted files in the installation and to restore its settings back to default including some of the settings that you might have customized.
