I am getting a problem with my HP Design jet 1000 Printer series which has stopped printing midway and showed an error code 0000D8 005D0273 in the plotter.
I have tried troubleshooting the problem with the help of a technician but was unsuccessful.
Can you please tell me how to fix this error?
Error code 0000D8 005D0273 encountered with my HP Designjet 1000 Printer series
Hi Avery
If the explanation for error would be laptop or network, then it ought to get resolved with the below mentioned troubleshooting steps:
Perform a power-cycle:
You would have to be compelled to turn off the Printer initially place.
Remove all the data/network cables, make sure the printer is totally isolated.
Power-on the printer back once more.
If you get an equivalent error once more, then continue with the steps below:
Turn-off printer and take away the EIO network card out of the printer.
Power-on the printer.
If the error disappears, isolate additional by turning the printer off, and so install the EIO card in numerous EIO slot. Stimulation printer, if the error doesn't seem, then original EIO slot on the natural philosophy module might need gone unhealthy.
Please learn that the natural philosophy module is replaced along with your convenience, as you may be able to use the printer with full practicality by victimization the opposite EIO slot.
If the same error reappears once more, the EIO card could also be defective. Continue with the remaining steps.
Please make sure the usage of the correct network card model as there is a distinction within which models square measure supported by the various versions of printer computer code.
Turn-off printer and reseat the computer code and memory DIMM(s). The memory ought to be HP supported one.
Turn-on and arrange to check the practicality of printer.
If the difficulty solely happens whereas the printer is on a network, impress a equidistant affiliation to rule out a network issue. If printer works via a equidistant affiliation, there's possibly a network issue. Verify that the printer's computer code version is current, print a Service Configuration sheet, and phone Jetdirect support for additional help.
If the matter persists, plow ahead and replace the computer code.
