Error code: 0x0000051 – free stream GOM player
When I go for launching the installed free stream GOM player, I receive an error message like the one- “Error code: 0x0000051" and it is unable to load the stream.”
I have attempted for reinstallation to solve the issue.
Can you please help me?
Answered By 0 points N/A #176827
Hello Jesus D Stowe,
Gom Player is a freeware media player which has built-in, popular audio and video codes. Its main feature is that it can play broken AVI files.
If you are able to install other applications on your PC without any problems, your Windows and all of its features are okay. Your problem is that the Gom Player application may be crushed, or some of it’s parts may be broken.
Download the latest version of the Gom Player here and install it.
Now, you are able to install it easily.
Answered By 590495 points N/A #321620
If you are trying to play a video or a movie in GOM player and you receive an error, check if the video format is supported. Among the video formats supported include:
  • .avi
  • .ogm
  • .mkv
  • .mp4
  • .k3g
  • .ifo
  • .ts
  • .asf
  • .wmv
  • .wma
  • .mov
  • .mpg
  • .m1v
  • .m2v
  • .vob
  • .m4v
  • .3gp/3gp2
  • .rmvb
  • .rm
  • .ogg
  • .flv
  • .asx
  • .dat
If you can’t play a particular format because of a codec problem, you can install K-Lite Codec Pack. Try downloading K-Lite Codec Pack Mega. This mega variant of the K-Lite codec pack is the largest of the four variants: basic, standard, full, and mega. This codec pack provides everything that you need to play all your audio and video files.
This codec pack also includes ACM/VFW codec which can be used by video encoding/editing programs. This codec pack includes Media Player Classic so you can immediately play your files. The latest version at the moment is K-Lite Codec Pack Mega 15.0.4. For Windows XP Service Pack 3, the latest and last compatible version is K-Lite Codec Pack Mega 13.8.5.
Try also downloading the latest GOM Player. It supports Windows XP Service Pack 3 (32-bit only), Windows Vista (32-bit only), Windows 7, Windows 8.x, and Windows 10. It requires 2 GB RAM and 200 MB free space. You can also use MPlayer for Windows or download the latest VLC media player.
On the other hand, if you are trying to stream a video from a website, check the URL of the video.
