Error code – 0x80043ac9. Check documentation
Hello experts!
I encountered the following error while trying to sync my Outlook 2003 calendar entries with my Curve:
Error encountered. Error code – 0x80043ac9. Check documentation.
While the above error is popping up, it also displays in the screen:
"Processing Device Calendar"
"Record 20 of 80 Records"
There is NO PROBLEM while syncing Outlook Contacts or Memos. The problem is only with syncing Outlook Calendar. I've found the similar problem in other post which says the problem occurs when syncing contacts and the given solution was to remove Birthday contact entries:
But there is no any Birthday in my contacts, and again I say my problem is with Calendar, not Contacts.
So can anyone share any idea how to solve this, or have anyone encountered similar problems? May be it’s about with "bad" calendar entries in there somewhere, but I can’t figure it out.
Thanks for reply.
Intellinsync
