rangu
10 points
Posted on - 03/23/2012
I am trying to run Adobe Dreamweaver but it always show an error 0xc0000005. I called for a support and after spending many hours talking to a technical support, they told me that it is a problem with my Windows setting. Other Adobe programs works just fine except for this one. Can someone please help me on resolving this issue? Thanks.
Error code 0xc0000005 Adobe dreamweaver
Hello Rangu,
This error is due to a faulty RAM or to a incorrect installation of driver. From where did you download the driver of your Adobe Dreamweaver? If you have downloaded it from some illegal website, then you are most likely to receive this application error. So I will suggest you to uninstall the Adobe Dreamweaver components in your computer and download it again from the Adobe website or any trusted site. Another way to resolve this is to run a memory test to check if you have a faulty memory card. If there is an error found, try to change your computer's memory with a new one.
Hope this answers your question.
Good day.
Following the given methods might provide a solution to your problem.
Method 1. You have to launch Dreamweaver in clean boot and check whether this provides a solution.
Method 2. Go to this path (C:Documents and Settings<username>Application DataMacromediaDreamweaver 8ConfigurationWinFileCache-[random_numbers].dat) and delete the file. Then delete all content inside Sitecache.
Method 3. If the problem still persists this might be because of corrupt files. Try uninstalling and then re-installing the software.
Hope this information proves useful.
