I have Windows 7 on my laptop. It is 32 bit version. When I install Google Chrome and open it, it gives an error with error code (0xc00000a5). I really want to fix it. Please guide me how can I remove this error? I have tried reinstalling but to no use.
Error code (0xc00000a5) occurs in Google Chrome on Windows 7.
To fix the issue of error code (0xc00000a5) , check for solutions listed below.
1. Check for latest version of Google chrome. It might be possible that the version of Google chrome is beta version. So download the latest version and install it.
2. Check if Google Chrome is set to work in compatibility mode. If yes, we need to disable the option to run in compatibility mode.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
