dj_dreamz
Posted on - 07/21/2011
My laptop will not boot up it has the error code. 0xc0000135 the application failed to initialize properly. Can anyone help please.
Janine08
5 points
Error code 0xc0000135 the application failed to initialize properly
If your application failed to initialize with the error code 0XC0000135. It is because in the your system it is not installed the Microsoft Framework 2.0!
Download and Install the Framework 2.0 at the following link:
After you have installed the Framework 2.0 in your system, Androsa FileProtector will be initialized successfully!
EvanX
This error is generated by Device Manager when you are booting and cause for this error probably that you haven’t installed .net Frame Works in your PC. Much modern software requires .net or other dependency programs to execute.
If you haven’t installed them this error message is obvious. If you are using Windows XP you can get relevant version of .net for free by visiting Microsoft site. If you have Windows Vista .net 3.0 is installed as default in your system and you can upgrade to the required version. You can check which version is installed in your PC by downloading this simple tool from
https://www.microsoft.com/en-in/download/details.aspx?id=5205 and it reveals all the detail about your .net version.
Update your OS frequently and keep the OS in shape.
