ave broers
70 points
Posted on - 07/23/2019
I randomly started getting this error code 0xc000022 from Windows. To help you out, let me inform you that my system is completely updated and I have not installed any new programs. I do not know much about computers. How do I remove this from my system?
Error Code 0xc000022 Fix Windows 7
Ans) The error code you are getting, 0xc000022 is particularly nasty. The exact cause of this error is impossible to find remotely. This error is generally caused by corrupt system files and viruses or malware. This error is also seen in case of incomplete installation or uninstall of a program.
What this error means is that there is some problem with the system registry of your computer. Now, advanced users can remove this error by manually editing their system registry however, common users should not attempt doing so because if gone wrong, this can make your operating system unbootable. It is suggested that you call up a technician to help you out with this.
