I am not able to complete the Windows Upgrade because I keep getting error code 0xc1900208 and I cannot seem to get past it. I need to complete the upgrade as soon as possible. Is this error fatal or can it be resolved?
Error Code 0xc1900208 Fix Found
The error code 0xc1900208 usually occurs when an incompatible program is present on the system. The program is incompatible with the new version you are trying to upgrade to. This incompatible program prevents you from completing the Windows Upgrade.
The solution to this problem is pretty straightforward once you find out the program that is not compatible with the new Windows. After identifying the program, all you need to do is uninstall the program using the Control Panel.
