larryiresto
30 points
Posted on - 05/25/2012
Hi, I am using the Hotspot Shield application on my iPhone. But sometimes I am facing a problem while entering my Netflix account. Every time I try to access the account an error occurs showing “error code 139”. I tried several times solving the problem by switching the device on and off, but nothing happened. Can someone help me how to fix this? Thanks.
Error code 139 while logging in Hotspot Shield via Netflix
Hello there Larryiresto. It is very sad to let you know that Netflix does not work anymore with this VPN app. This is likely due to the TCP Connect problem or an authorization related issue. Hotspot shield is expected to soon come up with a fix to this. For now, what you can do is try to uninstall the app and re-install the app and check whether it gets solved or not. If not, you will have to either shift to a different program or you will have to wait for an updated version. Hope your problem gets solved soon.
